Brake Pin Boots
Old May 18, 2007 | 06:35 AM
digger1978's Avatar
digger1978
Default Brake Pin Boots
I have torn one of my rear brake pin boots. I went to my Honda dealer and they cannot locate a part number for the pin boot. They can get any part of the entire rear brake assembly except the boot. I really find this hard to believe. They told me my only option was to get a new brake caliper assembly. I found that absurd. This is for a 1994 Civic Si. Anyone know the part number? I know Acura shared some components on the Integra. Attached is a link to the parts diagram. It is number 21 on the list. Pin Boot
Old May 18, 2007 | 09:28 AM
ianlee420's Avatar
ianlee420
94teggsr
Default autozone!!
jus had to replace the ones on my teg not sure of part number but go to autozone n ask them for the caliper pin dust covers,should come in a brake hardware kit!! do the pins still slide in n out?? mine were rusted fast had to buy new caliper mounting brakets,pins n the dust covers good luck hope this helps a little,oh yeah make sure you put some synthetic(?) brake lube in side of the dust cover if you ever find them them!!
Old May 18, 2007 | 10:47 AM
bnuk's Avatar
bnuk
Yeah if you can locate a caliper rebuild ket they will be included. I usually get them from rockauto.com but I'm sure they pretty easy to find. i would take the pins out and sand them down if they aren't clean (>400 grit)
Old May 18, 2007 | 11:33 AM
digger1978's Avatar
digger1978
Went to Autozones website and low and behold Brake Caliper Bushing Thank you for your help.
