Ground wire locations
v-card member alpha
I assume it's a manual, correct? (said switch and not range sensor or whatever it'd be)
Also, you didn't mention checking the bulbs but I'll assume you did that too.
You could try bypassing that switch, jumping the connector to see if that works but if you're sure the switch is good that pry won't help.
If it's both lights being affected and not the switch I'd check to make sure all connections (start with those easiest to access) are clean and tight.
I know some people have had your problem and it was because a connector somewhere down the line had worked it's way loose.
