KONI Yelllow Ground Control for road /track ??
Old May 16, 2007 | 02:04 PM
trevek10's Avatar
trevek10
Default KONI Yelllow Ground Control for road /track ??
this is a poll if you run a koni yellows with ground controls or you run another setup.... do you you like what you have or do they have problems... ive herd that shocks and sleeves make noise...tell me if im wrong
write waht you drive and if you like the suspension
more important if you run auto x and DD
Old May 16, 2007 | 03:54 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Running GC/Koni Yellows custom spring rate 350F/450R with a 22mm sway bar. I autocross and daily drive my car. It is a very comfortable ride and the only suspension noise I get is the squeaking from my toasted rear trailing arm bushings.
What I like about GC/Koni Yellows:
+Full rebound and ride height adjustability
+Custom rates
+Easy assembly
+Solid construction
+Performance to price ratio is very high
+They look cool
+Easy installation
What I don't like about the GC/Koni Yellows:
-Spring not preloaded until car is on the ground
-OTS Koni Yellows can't handle spring rates higher than 500 lb/in. SPSS revalved Koni Yellows are required.
-If you want to slam the car, you need the GC tophats
Old May 16, 2007 | 07:43 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
i had' 'em on my ride a while back. i loved 'em very stiff on my setup. the yellows are the best shocks for the civic. you can't go wrong.
i'd recommend the following spring rates:
450 front 550 rear by gc
and yellows should be near the edge of the dampening, but you could probalby have gc setup them and revalved for your setup when you order everything through them.
Project EVA - The Track Package
Project EVA
Old May 16, 2007 | 08:02 PM
trevek10's Avatar
trevek10
keep um comming
Old May 21, 2007 | 09:13 PM
jesusublime99's Avatar
jesusublime99
I drive '95 GSR with Koni yellows and 450F/350R GCs with a 22mm sway bar/tie bar combo. This is my weekend car and I drive it spiritedly everywhere I go.
I've only had this setup for about 2000 miles, so far, I love it, comfort and performance at a low price. No noises or squeaking here.
Old May 22, 2007 | 05:52 PM
trevek10's Avatar
trevek10
well the research is done i just got the koni gc setup with custom spring of 400f 350r... i havnt got it out of the box yet but when it arives from what ive hurd...i will be more than pleased ...i just wana say thanks to everyone that gave me some input
nd once the b18 c1 goes in i think it will be ready for some action through the canyons!!!!!!!
i love MALIBU'S CANYONS
