shifter wobbles left and right(unstabilized)
Old May 16, 2007 | 06:34 AM
Xpress's Avatar
Xpress
Default shifter wobbles left and right(unstabilized)
does anyone know what causes shifter to unstabilize and wobbles left and right?
I'm experiencing this in my civic, its a second gen..
Old May 16, 2007 | 07:21 AM
lowbrow's Avatar
lowbrow
12:00AM Atlanta time...
I had it happen in my 6th gen, it was a worn out bushing on the bottom of my shifter. Replaced it and it was tight like new.
Old May 16, 2007 | 07:39 AM
Xpress's Avatar
Xpress
thanks, i knew it might be a worn out bushing.
Old May 16, 2007 | 12:07 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Yup replaced mine too with an Energy Suspension polyurethane bushing. Fixes every single time.
Autocross Help Page
Old May 18, 2007 | 12:57 AM
asimdada's Avatar
asimdada
Do you mean, ur shifter has lots of FREE play? Cause mine has it. I think the previous guy had a short shifter installed, and it has alot of play. How can i get that fixed?
Old May 18, 2007 | 03:25 AM
m735is's Avatar
m735is
When I installed the ES front and rear bushing, that didn't fix it. It was the bolt, nut, sleeve orings and little plastic hats at the bottom of the lever. All purchased through Majestic for about $30?? I even bought a spare set and didn't need them after about 75,000 miles. Really tightens up the lever!
Old May 18, 2007 | 04:53 AM
uo959's Avatar
uo959
I have the same problem...could I get all those at a local auto parts store?? If so what kind of kit is tha called?? What would I tell them?? And where exactly is all that stuff located??
Old May 18, 2007 | 12:31 PM
m735is's Avatar
m735is
I bought mine from hondaautomotiveparts.com (Majestic Honda). Or you could go to your local dealer, but you will pay alittle more.
If you go on Majestic's site they will show you the diagram, part numbers, list price and their price. I'm talking about the connection between the bottom of the lever and the shift rod.
Old May 21, 2007 | 04:47 AM
uo959's Avatar
uo959
What's it called at Majestic??
