Keyless entry 02 Civic
Old Apr 24, 2007 | 04:32 PM
carx0x's Avatar
carx0x
Default Keyless entry 02 Civic
Is the keyless entry system standard on a 2002 Honda Civic LX, if not how can I check if it has one? I just got this car but it only came with one key from the dealer, I want to buy a key fob/transmitter from ebay, but I don't know if my car has a keyless entry system installed.
Old Apr 24, 2007 | 05:01 PM
cpvdh's Avatar
cpvdh
here are install instructions and parts numbers
http://www.handa-accessories.com/civ...ckeyless01.pdf
you can check under the dash and see if the wiring is in place for the keyless entry, if it is then get your remote and enjoy
if the wiring isnt there, then start searching for the parts
good luck
Old Apr 24, 2007 | 05:36 PM
carx0x's Avatar
carx0x
okay I can see the harness, but there so many wires shoved in that little place I can't see the rest of it. How can I find the FCC ID for the transmitter w/ out moving the wire around?
Old Apr 24, 2007 | 05:55 PM
cpvdh's Avatar
cpvdh
you lost me
so you have the keyless entry harness?
what is a fcc id?
here are programing instructions for the remote if that is useful
http://www.handa-accessories.com/crv/KEYLESSPROG.pdf
Old Apr 24, 2007 | 06:53 PM
carx0x's Avatar
carx0x
I see the harness, but on ebay there is two remotes with different FCC ID numbers:
1. OUCG8D-344H-A
2. NHVWB1U521
From what I understand the FCC ID numbers must match the car in order to work.
However I do not know which one to get. Also, some of the remotes on ebay have a trunk button, will this work on a 02 Civic LX?
Old Apr 24, 2007 | 07:02 PM
cpvdh's Avatar
cpvdh
im not sure which one it would be
call your local honda dealer and ask for a part number, i am sure they will know
i am pretty sure there is not a trunk release button though if that helps
sorry i couldnt help more
Old Apr 25, 2007 | 05:48 AM
carx0x's Avatar
carx0x
Actually what I thought was the harness is not the harness. Therefore I do not have a keyless entry system installed. However, the keyless entry unit (not transmitter) has been DISCONTINUED by honda. I can't find a OEM kit anywhere.
Is there an aftermarket kit that I can buy that does not require actuators? More specifically, is there an aftermarket kit that I can plug into the fuse box like a normal OEM kit?
Old Apr 25, 2007 | 06:13 AM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
you only need actuators if you don't already have power door locks.
Old Apr 25, 2007 | 07:25 AM
+1
there are plenty of aftermarket remote entry kits out there. without doing some digging i cant recommend any one of the others but look around, they are there.
Old Apr 25, 2007 | 05:57 PM
19.3secS2K's Avatar
19.3secS2K
Originally Posted by rebeld
+1
:werd:
go to the local stereo shop. usually they run tint and alarm specials.
