power locks
Old Apr 17, 2007 | 12:15 PM
Civic SiR's Avatar
Civic SiR
Default power locks
i have a 1997 honda civic ex and the problem is that the power locks won't close all the way. i need some help. also what would make my car faster without having to spend thousands of dollars.
Old Apr 17, 2007 | 08:39 PM
fdavie's Avatar
fdavie
Lose weight. It won't do much but its free. Otherwise you're SOL, it's easy to spend money on a Civic and not change the speed much at all, why would you think there's a free way to get faster.
Old Apr 17, 2007 | 08:52 PM
cpvdh's Avatar
cpvdh
is it that the driver door wont lock while the door is open?
Old Apr 19, 2007 | 11:37 PM
A-series's Avatar
A-series
v-card member alpha
Yeah, that's what I was thinking.
Edit:I wasn't planning on providing the "Everthing you ever wanted to know about Honda automotive lock operation" but here it is...
Whether your honda has power or manual locks, you can't lock the driver's side door unless (1) you close the door, or (2) you pull the handle while you lock it.
This applies to both pushing it to the locked position manually or using the power switch. You can pull either the interior or exterior door handle, your choice.
Also, this may not apply to all but it does to 5th gen civics: If for some reason you are about to close your door and the doors are locked, if you push the switch to unlock them without first pulling the handle all doors will remain locked, not just the driver's door.
I figured this out through curiosity, not sure how you end up in that situation otherwise but that knowledge could prevent someone from being locked out.
Knowledge is power!!! :lmfao:
Disclaimer: Some details may be different on 21st century Honda/Acura automobiles.
Old Apr 20, 2007 | 07:06 AM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
this was true on my 90 accord, my 96 civic, my dads 00 accord v6, and my moms 02 civic.
Old Apr 20, 2007 | 07:09 AM
Wharbone's Avatar
Wharbone
I almost alway lock my drivers door inside by pulling the handle while locking.
Old Apr 20, 2007 | 07:40 AM
Ambiguous's Avatar
Ambiguous
:werd: def the only way to go lol
Old Apr 20, 2007 | 11:01 AM
19.3secS2K's Avatar
19.3secS2K
keyless entry > stupid doorlock trick
Old Apr 20, 2007 | 11:22 AM
cpvdh's Avatar
cpvdh
the guy that i bought my civic ex from was clueless
he thought you had to lock the car with the key after the door was closed
when i checked out the car for the first time i explained how to use the door handle, and also that the car came with keyless entry, all he needed was a remote
he felt like an idiot after i told him that :lmao:
Old Apr 20, 2007 | 12:32 PM
19.3secS2K's Avatar
19.3secS2K
I knew a girl who had an '01 civic when they first came out, and she would brag to no end about it having a system that "kept you from locking your keys in the car."
I showed her the handle trick, and pretty much shut her up.
