Car Quit Need Some Suggestions
Old Apr 17, 2007 | 04:17 AM
Bad_Religion's Avatar
Bad_Religion
Default Car Quit Need Some Suggestions
i was driving(i drive a 92 civic with a d16a6 engine is from a 91 civic si) home from were my daughter was and when i was about home i was pulling from a stop sign and soon as i was getting ready toshift to 2nd my car just quit, when i try to start it all it does is make like a wining noise. i thought i blew a rod but my oil was still full, i need some ideas because i need to get back and forth to work, i never expected this to happen lol..
Old Apr 17, 2007 | 05:38 AM
ariza034's Avatar
ariza034
SuMaDiNaC
timing belt?
Old Apr 17, 2007 | 12:22 PM
Bad_Religion
yea thats what it is ithink going outside right now to make sure, i have no idea how tochange it tho
Old Apr 17, 2007 | 12:28 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Might need a new head
Old Apr 17, 2007 | 12:51 PM
Bad_Religion
yes its the timingbelt. does anyone have a how toguide with pictures on how to change it??
Old Apr 17, 2007 | 01:05 PM
wilsel's Avatar
wilsel
http://www.honda-tech.com/zerothread?id=649277
Old Apr 17, 2007 | 01:17 PM
silvic00's Avatar
silvic00
:noes: hopefully your lucky and didnt take anything else out when the belt went, but u might as well replace the tensioner and water pump while your at it
Old Apr 18, 2007 | 01:00 PM
mberndt's Avatar
mberndt
Sure thing, it's the timing belt.
I'm pretty sure the SOHC motors are "interference motors", in that the valves will contact the pistons and then bend if the timing belt snaps.
That is why a timing belt job is PREVENTATIVE maintenance.
This is a most common problem with people, as they only fix things when they break. Problem is if you don't get the timing belt replaced at a regular interval, it can break and then basically ruin the motor, cause it will cost lots of $$$$ to fix the bent valves.
Most people will just buy a new motor/head rather than get the ruined one fixed...
And you ALWAYS replace the tensioner and water pump when doing a timing belt job.
Good luck!
Old Apr 18, 2007 | 07:15 PM
sleezye's Avatar
sleezye
so even if the tensioner is good he should still replace it
Old Apr 19, 2007 | 06:58 PM
silvic00's Avatar
silvic00
Yes, why have it weardown and risk the chance of the timing belt jumping a tooth or two+....its alot easier to do them (belt, tensioner, water pump) all at once and is part of scheduled preventive maintenance
