Wont go into gear.
Ok the problem started out of nowhere when i pulled up to a light i noticed a small amount of grinding that i could feel through my clutch when i pushed it in. When i went to pull off from the light I couldnt get into gear at all. So I allowed my car to roll down the hill off of the road. I turned the car off and look under the hood, nothing. I turned the car back on and placed it into 1rst and I felt the same grinding sensation but much worse. I drove it home and when i went to leave it would not go into gear at all and if i forced it it would grind like hell.
I have a new six puck clutch with factory pressure plate and flywheel. I also have a new slave cylinder which I bleed to no avail. My buddies put the clutch in it for me while I was doing something else. I have a jdm b16 with a hydro (of course) and I think a Non-lsd y1.
Any suggestions would be greatly appreciated. Even though I usually just get bashed. The tranny will be coming out tommarow.
which is bullshit cause i just put all this shit togather like 3 weeks ago.
Do you think excessive wheelhop (two visits to the track and a shitload of street driving) could of loosend up something.
You usually get flamed because you are a tool.
I'm guessing either shift linkage or clutch. Total tranny meltdown seems unlikely.
BTW, cobbling together a clutch out of various parts... not the wisest idea imho. If the clearances aren't right, you might have destroyed the plate or the clutch. Was the clutch sprung or unsprung?
I had a clutch disk spring come out of place in a '94 b16. Fine one minute, then it wouldn't shift into any gear, but I also couldn't depress the clutch. When I took it apart there was a clutch spring broken into two pieces and all ground up in the bell housing. Replaced the plate and disk and everything was fine.
