95 civic acting up...
Old Apr 3, 2007 | 07:28 PM
mz_xy's Avatar
mz_xy
Default 95 civic acting up...
ok so my car was running fine but recently the steering wheel starting vibrating a lot and the car if i dont grab the steering it goes to the right and shakes a little. i checked the oil and all that but everything seems fine. what could it be? a mechanic said something about some bars that connect the tires but i dont know. dont wanna get ripped off either
Old Apr 3, 2007 | 07:50 PM
nyioo7's Avatar
nyioo7
does it happen when it's at high speed? or breaking? or acclerating or decclerating?
@ high speed check tire, alignment, and axles
all the other cases, axles
dude! u can just grab tht axles and shake it to see if it's lose or not, i mean both side. go do it right now. haha.
Old Apr 3, 2007 | 07:52 PM
Snoopy's Avatar
Snoopy
been there done that
check your axles and tie rods
Old Apr 3, 2007 | 08:11 PM
mz_xy's Avatar
mz_xy
i dont even know what an axle is. im barely trying to learn this girl aint there just yet. it shakes when i get past 35 and a lot of vibrating on the steering wheel
and i did go grab in there right now but dont kno what im looking for
Old Apr 3, 2007 | 08:30 PM
nyioo7's Avatar
nyioo7
those are the ones tht're connecting ur engine and ur wheels. u should see a black bar underneath the intake, and starter.
the other side one's kinda hard to reach but it's similar, it should be underneath alternator.
Old Apr 4, 2007 | 05:27 AM
silvic00's Avatar
silvic00
Axles are the (black tubular, usually) ones that connect your transmission to your wheel hub. You can jack car up/ pull up on ramps/ turn your wheel completely to one side or the other to see the axle on each side. There is a nut (32mm, i believe) that holds the axle to wheel hub that you can see by either removing center cap of wheel or removing wheel all together, this nut should be tight and dimpled to prevent loosening. At the transmission side you should not see any of the splines where the axle slips into the tranny. Hope this helps, any more questions just ask, someone will answer.
Old Apr 4, 2007 | 11:42 AM
Thi3v3z's Avatar
Thi3v3z
im willin to bet u just need a tire balance, or alignment.
