100k miles, vibration ..can anything be done?
Old Mar 27, 2007 | 04:23 PM
BenB's Avatar
BenB
Must stay awake
Default 100k miles, vibration ..can anything be done?
I'm sorry if I over looked a thread already about this topic..I just couldn't find something about it.
My car recently passed 100k miles, and is a 2000 civic ex. I've had it for over 3 years and when I got it, it had under 50k in miles. Now when I'm idle I feel a vibration in my seat and steering wheel. This didn't happen until the last 10k or so miles.
I'm over due on a timing belt, and that'll probably get done within the next month. If that doesn't help resolve this problem, what will? Or is it just something that comes with the age of a car?
Old Mar 27, 2007 | 05:40 PM
qtiger's Avatar
qtiger
Offhand, the only age-related cause of behavior like that (assuming your car is idling normally) would be your engine mounts.
You can take a peek at them as best you can, but if you aren't a hardcore DIYer, that could be a quite expensive issue to diagnose and fix.
Old Mar 27, 2007 | 06:42 PM
BenB's Avatar
BenB
Must stay awake
Thanks for the reply. It's idling below 1000..around 800 if I had to guess. I figured something like that, however I didn't want to throw options out there thinking someone would say that because I suggested it.
I can only imagine how much of a pain engine mounts would be.
Old Mar 28, 2007 | 09:40 AM
ari_one's Avatar
ari_one
Actually the engine mounts aren't that hard to do yourself. I just did my front and both sides on an 01 EX. Take a good look at them and see if they are broken, mine were easy to see because the front and one of the sides had actually collapsed. When you look at them look to see if the bolt is centered inside the mount, if it is not then there is a good chance the mount has broken.
Old Mar 30, 2007 | 10:25 PM
qtiger's Avatar
qtiger
If you either have access to the proper tools or are mechanically savvy it's not completely terrible. Just time consuming.
Old Mar 31, 2007 | 07:41 PM
nyioo7's Avatar
nyioo7
always check plugs and wires.
