93 dx problem
Old Mar 26, 2007 | 11:02 AM
crx88's Avatar
crx88
Default 93 dx problem
ok..my 93 dx won't start after i stalled it, everything works fine and i can roll start it but it won't start cold(sitting)...when i turn the key the starter won't click or anythign it just gives me a silence....the fuel pump comes on...but the starter won't work...any ideas?
Old Mar 26, 2007 | 05:07 PM
TotalVelocity's Avatar
TotalVelocity
Main relay.... Thats what it is.
Old Mar 26, 2007 | 05:51 PM
Wharbone's Avatar
Wharbone
I may be wrong, but if I remember correctly, the fuel pump would not come on if the main relay was out.
Old Mar 26, 2007 | 05:57 PM
Wharbone's Avatar
Wharbone
I'd guess either your starter or ignition switch.
How is your battery? Might want to test that.
My wife once had this problem... She wasn't pressing in the clutch... h:
Old Mar 26, 2007 | 11:33 PM
A-series's Avatar
A-series
v-card member alpha
Could be wrong but I don't think it's the main relay(replacing soon on my car) or the ignition switch as I don't think push starting the car would work in those cases.
My guess would be battery, starter or the connection between the two.
Old Mar 26, 2007 | 11:41 PM
Civic2Scooby's Avatar
Civic2Scooby
things to check: battery, all connections involving starter/battery and I would also jump the clutch safety switch to rule it out as well.
Old Mar 27, 2007 | 03:14 AM
m735is's Avatar
m735is
Are you getting voltage at the starter? If not, check the switch, cables, battery connections and battery. If you are, have the starter checked.
