tein springs instead or eibach prokit?
Old Mar 24, 2007 | 03:20 PM
dspencer24's Avatar
dspencer24
b18c ftw
Default tein springs instead or eibach prokit?
Right now i have eibach prokit and kyb agx spring/strut with a 17x205x40 series tire. And i was wondering if The tein springs would ride better and if it would give my car an even drop untead of the back being a lil lower then the front like on the eibachs? I use this car for daily comutting. or can you guys recomend something that rides good, not to bouncy and, and not to expensive?
Old Mar 25, 2007 | 09:25 AM
dspencer24's Avatar
dspencer24
b18c ftw
anybody???
Old Mar 25, 2007 | 09:39 AM
bmallen11's Avatar
bmallen11
iLURK
A lot of people swear on the koni yellow/ground control setup and they only run $800-$1000. They are coilovers so you will be able to pick what ride hight you want.
Old Mar 25, 2007 | 09:42 AM
Wharbone's Avatar
Wharbone
The S Tech Tein springs will give a more comfortable ride. They are not meant for performance.
The Eibach's will be stiffer, but better for performance.
Old Mar 25, 2007 | 12:52 PM
dspencer24's Avatar
dspencer24
b18c ftw
will 17's with a 40 series tire rub with the tein s springs
Old Mar 25, 2007 | 12:57 PM
dspencer24's Avatar
dspencer24
b18c ftw
i heard they are not ment for koni's
Old Mar 25, 2007 | 03:26 PM
Wharbone's Avatar
Wharbone
Probably. Depends on the offset.
You heard wrong.
Old Mar 25, 2007 | 04:00 PM
dspencer24's Avatar
dspencer24
b18c ftw
ummm check these ones out are these the worng oneshttp://cgi.ebay.com/ebaymotors/NEW-G...05090728QQrdZ1
Old Mar 25, 2007 | 04:43 PM
Wharbone's Avatar
Wharbone
Ground Control makes coilovers just for the Koni shocks.
I think they are the same coilovers w/ a sized sleeve and clip. That is why if you buy from ground control, they are $40 more expensive.
Old Mar 25, 2007 | 05:06 PM
dspencer24's Avatar
dspencer24
b18c ftw
aahhhh makes sense do you know where to get ground control coilovers that fit them, or would tokicos work just as good.. Or should i just stay with kyb agx's
