axle problem again
I am havin the same prob still my passenger axle is binding in corners only with the clutch disengaged . i had prob bad when i first did the swap but i changed the axle to a abs axle the said it was lil longer but they look the same to me an i put in some lsd additive with gm syncromesh it doesn't do it as bad but i noticed on the other axle tranny hub had like a 1/4 inch play like the snapring didn't pop into the groove . i figured the first axle was fuct up so i got the abs an it has like 1/8 play . so you can move that hub in an out the tranny . now if i take my halfshaft out an make sure i can see that snapring lock in place what could be the prob ? if it doesn't reach i also have a prob. ? thanx 4 info:jlammy:
