Code 19 Help..
Old Mar 20, 2007 | 03:46 PM
JerryN2U's Avatar
JerryN2U
Default Code 19 Help..
I'm kinda confused here.. I'm getting my check engine light coming up. I have a B16A in a Honda Civic EX. I used the EX wire harness and converted it to run on the B16A. I then used a OBD2b to OBD1 harness converter. Now I'm throwing Code 19. I'm running a 37820-P30-020 ECU that came with the encine which is the correct ecu.. My transmission is manual. is there a way to eliminate it or do i have the wrong ecu??? the car runs fine. vtec kicks in and everything.. it's just that code it's throwing... any suggestions
Old Mar 25, 2007 | 05:52 AM
JerryN2U's Avatar
JerryN2U
Does anyone have any ideas on this.. As far as i know, the CPU is for a manual transmission..
Old Mar 25, 2007 | 06:27 AM
teg92's Avatar
teg92
WHAT OK YEAH!
code 19 is Automatic transmission lockup control valve. Kinda of weird since you have a manual. Try clearing the code and if it comes back try using a different ECU
