Difference between manifold and header
Old Mar 16, 2007 | 12:18 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Originally Posted by Snoopy
most often referred to as a turbo manifold
nah turbo header.
Old Mar 16, 2007 | 01:24 PM
2gr84u's Avatar
2gr84u
2gr84u
Originally Posted by Omniscient
nah turbo header.
ive never seen anyone refer to it as such
Old Mar 16, 2007 | 02:15 PM
passionateman's Avatar
passionateman
Originally Posted by 2gr84u
Just to help you out a little more, alot of the time when your dealing with turbos, people will refer to the portion that the turbo bolts upto as a manifold, just make sure that you can decern the difference when someone is speaking of a turbo manifold, and when someone is talking about a stock exhaust manifold.
I checked the recommedation page I got from the Honda dealer. It says that "Exhaust Manifold Leaking (Cracked)." So is it the header that I could purchase and it will replace this exhaust manifold thing?
Let me know.
Thanks.
Old Mar 16, 2007 | 02:20 PM
Snoopy's Avatar
Snoopy
been there done that
Let me know.
Thanks.
yes. exhaust manifold = header
Old Mar 16, 2007 | 02:51 PM
passionateman
All righty. Thanks. Do you think if I get a cold air intake like the aem v2 along with a header, will that give me some horse power?
Old Mar 16, 2007 | 03:00 PM
Snoopy's Avatar
Snoopy
bolt on's will not give you any noticeable hp. dont mistake increased throttle response with hp. and definitely dont spend $300 on an aluminum pipe and filter.
Old Mar 16, 2007 | 03:42 PM
passionateman
1. What do you mean by bolt on? You mean using these headers and air intake wouldn't make much of a difference?
Old Mar 16, 2007 | 03:44 PM
Snoopy's Avatar
Snoopy
that's what im saying
Old Mar 19, 2007 | 07:23 AM
njblacksol's Avatar
njblacksol
gangsta pancake
it will give you hp but you wont notice....it's so minimal i dun even refer to it as givin it any hp, i just say it helps me get to where i want to be
Old Mar 19, 2007 | 10:04 AM
My93Civic's Avatar
My93Civic
I haven't posted here for a while....I thought I'd try to help out.
Like others have already suggested a "manifold" is another term for "header".
The correct term is exhaust manifold which means the header (aftermarket term).
As for the quoted $950 for a stock header, that's crazy`! But not totally surprising as its coming from a dealer.
You can get an aftermarket header for cheap cheap money in the USA. So do not try to spend too much because it doesn't really matter with our little Civics, especially if your engine has had no work done to it.
I'd look into a Megan Racing 4-2-1 header because its cheap in price and most people have had no problems with it so far.
If you get a cheap price for something else which is name brand, jump on it. While your at it, I'd look and see if you can get it ceramic coated which will help the header from rusting down the line...
Good luck! Or if you don't care, head down to your local junk yard, and pick up a stock header from a Civic like yours....
