KYB agx front struts?
Old Oct 7, 2002 | 03:31 PM
DRTHV8R's Avatar
DRTHV8R
Default KYB agx front struts?
I just got some KYB agx struts for my HB, and there are no stops on the strut piston rod. When I put the car down there was nothing stoping the strut rod to come up thru the pillow mount, thank god the hood was open. Are these the right struts? Should they have stops or washers on the rod? HELP. Thanks.
Old Oct 7, 2002 | 03:32 PM
likaciv's Avatar
likaciv
Pretty Much its a Civic
you are supposed to transfer all the bushings washers and stuff from the old strut
Old Oct 7, 2002 | 03:43 PM
DRTHV8R's Avatar
DRTHV8R
the stock strut has a welded ring that holds the washer and bushing assembly. this is a tapered rod with no ring.
dantastic's Avatar
dantastic
cx power!
they install exactly like the stock struts, and make sure u use all the stock hardware
Old Oct 7, 2002 | 03:46 PM
dantastic's Avatar
dantastic
cx power!
the stock strut ring shouldnt be welded. i used a mallet to tap mine out
Old Oct 7, 2002 | 03:51 PM
DRTHV8R's Avatar
DRTHV8R
i change out a coil over set up so i do have the stock stuff, what should i do.
Old Oct 7, 2002 | 03:52 PM
likaciv's Avatar
likaciv
ya use the stock stuff, all of it should come off so it looks like the new one out of the box
