Fluctuating Idle
Old Oct 7, 2002 | 11:08 AM
Shift6's Avatar
Shift6
Default Fluctuating Idle
I recently swaped a b18b1 into my 95 civic and once i started everything ran and sounded fine except for a bad fluctuating idele that surges between about 1000 to 3000 rpm. Any ideas that might be causing this? thnx
brady
Old Oct 7, 2002 | 11:17 AM
ManTiS's Avatar
ManTiS
NinJA
vacuum leak
Old Oct 7, 2002 | 11:32 AM
Nelson's Avatar
Nelson
Administrator
Yeap, had that problem too, but it went away after a few weeks... it's a typical swap problem, so I've been reading.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Oct 7, 2002 | 01:41 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
depending on how far into it you went, it could be a bad gasket on the intake manifold, or in my case it was a bad seal at the throttle body. Most times it goes away when it's warm since the metal expands and seals the gap. Also check your hoses and PCV valve...
