Tps Setting?
Old Oct 7, 2002 | 05:46 AM
vernonhonda's Avatar
vernonhonda
Default Tps Setting?
I INTSALLED A NEW SKUNK2 TB THIS WEEKEND,AND NOW MY CAR RUNS LIKE A$$,I CHECKED EVERYTHING POSSIBLE!!!!! MY BROTHER IS TELLING ME IT IS PROBALLY MY TPS SETTING,SINCE IT WAS LOOSE ,AND I JUST TIGHTEND IT UP WHERE IT WAS.....
DOES ANYONE KNOW WHAT THE CORRECT SETTING ON IT IS (93 CIVIC EX ) WHAT WIRE'S TO I HAVE TO PROBE TO GET THE READING? I NEED HELP FAST,IT'S RUNNING LIKE CRAP!!!!
Old Oct 7, 2002 | 05:49 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
FIRST OFF TAKE YOUR DAMN CAPS LOCK OFF. There is no need to yell.
TPS setting? never heard of that, I think there is a TPS sensor/plug and whatnot but i don't think its adjustable. If it is, then disregard
I really just wanted to tell you to stop yelling.
Old Oct 7, 2002 | 06:50 AM
ManTiS's Avatar
ManTiS
NinJA
You can adjust the idle with the screw (if that's what you're talking about)
Old Oct 7, 2002 | 07:43 AM
qtiger's Avatar
qtiger
Did you get a check engine light?
Old Oct 7, 2002 | 09:25 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
It is adjustable. The voltage may be off. I don't have a manual handy though. I'm wanting to say the voltage is 4.5v at wot? Better get a book though unless someone else here knows it off the top of their heads. You'll have to probe the middle wire. The voltage should change when you have the key on, playing with the tb butterfly.
Old Oct 7, 2002 | 01:47 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
yup, 4.5 at WOT. Not sure on which wires off the top of my head. Check the gasket on the TB.
Old Oct 7, 2002 | 06:15 PM
vernonhonda
thanks guys,i'm buying a new gasket on tuesday,and i will set the voltage at WOT.don't i have to have the key in the on postion,and by hand open the throttle,then set it?
thanks for the reply's
Old Oct 7, 2002 | 06:42 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
you can do it with the tb off the car
just open the butterfly all the way... and put the mulitmeter on the pins on the tps sensor...
to see what voltage you are seeing
i thought it was 5 v at WOT, but it's been a while so i'd go with what speedracer exr said.
Project EVA - The Track Package
Project EVA
Old Oct 8, 2002 | 02:06 AM
SpeedRacerEX-R
I'll have to check my vafc and I'll let you know. I'll do that tomorrow afternoon and post back what mine's reading.
Old Oct 8, 2002 | 08:55 AM
SpeedRacerEX-R
.5v no throttle
4.75v WOT
