Need stock d16z6 fuel pressure?
Old Feb 20, 2007 | 03:19 PM
hatchboi's Avatar
hatchboi
Default Need stock d16z6 fuel pressure?
need to set fuel to stock pressure. it at 32 psi right now.
Old Feb 20, 2007 | 06:43 PM
Fuse's Avatar
Fuse
31 at idle fuel psi regulator vac hose on.40 vac hose off.Sound like you fuel psi is fine.
Do you have a specific problem you are trying to fix.
Old Feb 21, 2007 | 06:58 AM
hatchboi's Avatar
hatchboi
my car is not running right during hard acceleration
Old Feb 21, 2007 | 05:20 PM
Fuse's Avatar
Fuse
Have you looked at your ignition system.Check you cap for cracks or burn marks.Check to see if you rotor is tight also look for burn marks.Test your spark plug wires 25k ohm max.Check your spark plug gap at .043 of an inch or look for rounded electrodes.You should be using non plat ngk plugs.I would also look at your ignition timing 16 degrees at idle(the red mark in the middle of the 3 marks not the solo white mark).
Some other things to look at is cam timing marks are rite or valve lash.
What is the long story did you change some thing,add some new mods,or did it just come out of the blue.Any check engine lights are you running a turbo or an air fuel control??
