Will these doors fit?
please take my word for it. i have a 93 si and i dont have power windows, my friend's 92 si doesnt have em. several ppl that i know that has 92-95 si's, has no power windows. power sunroof on all si models is standard. power windows, no. in rare cases it could of been installed as an option from the dealer.
i gutted some 95 civic ex coupe doors' internals and converted my si's non power windows to power windows using all oem switches, regulators, and harnesses. its real easy to do, as long you get all the necessary components.
thanks.
yes its a complete bolt on affair. you will need the power regulators which will be connect to the sissor handles that hold the glass. oem switches for both sides, the harness that runs from both power regulators and switches. you will also need the under the dash harness that plugs into the fuse box, power window relay, and ex door panels or inner ex panel inserts because the hole that houses the power window switches is different then that of a non power window panel.
exactly. pulling the wires is probably the hardest part.
Quote:
Originally Posted by Dirtball
So power windows bolt right into non-power windowed door with no modifacation?
pretty much, just takes a little sweat.
Dont i have all that stuff on the EX door?So all i would have to do is take all that stuff like the wires and motor and what not and swap it?
Thanks for your help and input 19.3secFerio
