Engine Building question!!!!!!! PLEASE HELP
Old Jan 24, 2007 | 06:04 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Default Engine Building question!!!!!!! PLEASE HELP
Alright, well i got a couple of quick questions. Is it possible for me to install ARP rod bolts and torque them and put the stock pistons back in with the same bearings or is there no point!? I want to head stud it too. But let me know, i eventually plan on fully building my block and then going from there.
Old Jan 24, 2007 | 06:17 AM
Running925's Avatar
Running925
Your Powder Coater
what do you plan to do to this engine after it's rebuilt is the first question that needs to be answered?
Old Jan 24, 2007 | 09:15 AM
Snoopy's Avatar
Snoopy
been there done that
you need to have the rods resized after installing arp bolts. if you're going through all this you might as well replace the bearings as well.
Old Jan 24, 2007 | 12:19 PM
2gr84u's Avatar
2gr84u
2gr84u
why not just buy eagle rods, they come with arp hardware and then pick up some srp pistons. Both are fairly cheap. Hell you could even do the vitara piston/tuner toys rods set up for really cheap (assuming you have a d series) tunertoys.com has the rods for cheap, though they do have mix reviews
Old Jan 25, 2007 | 06:30 AM
RedlineBoyzCRX
EG6
I will be building the LS to turbo it.
So it will be a turbo build. I will prolly want to go with Eagle rods (ibeam or hbeam) and some CP pistons. i want the optional 3/8" rod bolt tho, for extra strength.
Old Jan 25, 2007 | 12:07 PM
Snoopy's Avatar
Snoopy
eagle only has h beams. so that makes that decision easier.
Old Jan 25, 2007 | 12:17 PM
fathergoat's Avatar
fathergoat
:3
didn't eagle switch to the ARP 2000 bolt to?
Old Jan 25, 2007 | 12:35 PM
Snoopy's Avatar
Snoopy
yes they did in 3/8 size. only the older eagles had 5/16 bolts.
Old Jan 25, 2007 | 09:49 PM
Omniscient's Avatar
Omniscient
warm butter on toast
I've been using tuner toys rods for a couple months with no issues.
Old Jan 26, 2007 | 08:45 AM
Running925's Avatar
Running925
Your Powder Coater
$300 - Eagle Rods with arp hardware
$400 - Wiseco Pistons from summit racing
Forged & ready for some power!
