quest. about sway bar for my hatch.
Old Oct 4, 2002 | 10:28 AM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
Default quest. about sway bar for my hatch.
hey ya'll, what parts do i need to buy from an 99-00 Si in order to fit the factory sway bar for my needy, looser than your boy's girlfriend suspension?
i'm thinking that i need the tie arm, sway bar, and something else!!! but i forgot
btw, how much would it approx. be?
thanks, clark.... I needed you!!!!
:thumbup:
Old Oct 4, 2002 | 07:53 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
are you talking about the rear or front sway bar?
i think you already have the holes for the bars...you just need to drill them out. not totally sure on that.
Old Oct 4, 2002 | 08:29 PM
str8edgexx's Avatar
str8edgexx
If its a rear you're looking for, I have one on my car, and this what you need:
the bar, 2 endlinks, 2 (one on each side) bolt/nut to attach each endlink to each LCA, 2 rubber bushings that the bar sit in, 2 little metal loops to hold the bushing & bar to the brackets, 4 ( 2 on each side ) nut/bolts to hold onto the loops, 2 brackets that hold the bushing/bar onto the car, and 4 (again, 2 on each side) nut/bolts to hold the brackets onto the car.
if you got all those parts from Honda, I have the actual part sheet and I think the list for all parts total is like $240. Do yourself a favor and get one used...I got mine for $80 for the entire setup.
Old Oct 5, 2002 | 09:30 PM
skubb's Avatar
skubb
not that TLC sh!t either
get the tegR bar. its like twice as thick as the Si.
I thought I read a how-to saying it was 137 from acura (bar alone)
Old Oct 6, 2002 | 02:16 PM
SUPER LAUBO
KiMBO's Hubby
thanks for the info...i'm going to do the back one, but try to get the Comptech one cause they come with a subframe reinforcement.
i'm actually look for the front and the front doesn't have any holes for it, i tried looking awhile back..:thumbup:
Old Oct 6, 2002 | 02:50 PM
SlowCivicHmm's Avatar
SlowCivicHmm
Try getting the ITR bar with the beaks kit....all you need is there...and GSR LCA"s........that's what I'm getting once I can afford it...so............
