tire ?
They are both good tires...it depends on what you mean by good. Traction, wet weather...performance?
Civic1.6VTEC
My bet is that the Yokohama AVS's will be more fun but wont last as long as the Kuhmo's. Im guessing the Kuhmo's have a higher treadwear rating. Mine are rated at 300. They are both decent in dry and wet traction.
I've only had experience with the Yokohama AVS Int. ...they stick like glue but wear out faster than my car They also sucked in wet weather traction. Basically performs the same as the Falken Azenis. Excellent on dry roads...crap on wet/snowy roads. I havent really done research about the ES100's.
Civic1.6VTEC
the treadwear is 280 for the yokohamas. the kuhmos are 340.
here
http://www.tirerack.com/survey/Surve...odel=AVS+ES100
here
My Yokohama's treadwear sucked! Well, that and the sidewalls on my Avid's were weak... I used to think Kumho's are cheap, but they are actually a pretty good tire for their money... comparable to Michelin's
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Honorary Moderator Alumni
Tread wear ratings are subjective. Each company makes their own ratings.
Grassroots Motorsports did a tire test in this month's issue. Pick it up (has blue WRX on the cover). They covered the Azenis, KDs, 712s, ES100, Hankook, Ventus, and several other tires.
Autocross Help Page
Autocross Help Page
