Side Clips
Old Oct 9, 2006 | 11:20 AM
quik's Avatar
quik
1337 h4x0r
Default Side Clips
Does anyone know how to safely remove the black side clips on the 5th gen civics? I've wedged one off with a flathead but wound up breaking it off of the plastic mounting. Is it possible to remove the side clips in a less destructive way?
Old Oct 9, 2006 | 04:17 PM
quik's Avatar
quik
1337 h4x0r
Bump
Old Oct 9, 2006 | 05:26 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Reach inside the fender well and push them thru with ur fingers.
Or were you talkin about on the door!?
Old Oct 10, 2006 | 05:56 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
If I remember right, you have to sqeeze the clip and then push it through. Shouldn't be too tough. But you fdefinitely have to do it from the back side.
Old Oct 11, 2006 | 08:02 AM
quik's Avatar
quik
1337 h4x0r
Yeah, I meant that plastic business that runs along the door, and barely extends onto each quarter panel.
So this means I have to take apart the doors?
Old Oct 15, 2006 | 12:10 PM
Saga Boy's Avatar
Saga Boy
On the inside remove the door panels then you can get to the clips. If you have a four door the front doors the first hole is a screw and the last clip towrds the fender cannot be reached which is a pain to weld and wipe. I'm in the process of removing my moldings one side is done primed and waiting for paint. peace
Old Oct 15, 2006 | 01:46 PM
Fuse's Avatar
Fuse
i lube them with rust penitrent(no joke)and use 2 flat heads.or thay make a pair of plires that work good i will send a pick if i remember.
Old Oct 15, 2006 | 04:01 PM
quik's Avatar
quik
1337 h4x0r
Thanks for the replies; I should say that the car in question is a 2dr. berginr, does the PB and dual flatheads method require disassembling the door, or can it be done from the outside of the car?
Old Oct 15, 2006 | 06:59 PM
Fuse's Avatar
Fuse
i would do i from inside. but i have done that before to make the job go faster on a new car its no problem on an old car thy might brake it your call.plus you can scratch the paint sow have a steady hand
