overheating when i boost
Old Oct 11, 2006 | 08:20 AM
t3t4delsol's Avatar
t3t4delsol
ok I tryed to start the car this moring and it turned over first click, I shut it off right away
Old Oct 12, 2006 | 04:20 PM
qtiger's Avatar
qtiger
Originally Posted by t3t4delsol
the car didnt not over heat at all, is it posible that i fried a ring?
No, its not possible. That would have nothing to do with your temp issues. Rings seperate oil from combustion, and do nothing regarding coolant. Your plugs are clean and not fouled because you are steam cleaning them with coolant every time you boost.
What color is the smoke coming from your exhaust on idle and on boost?
What does your exhaust smell like on idle and on boost?
Do you notice cars behind you on the road using their windshield wipers even though it's not raining?
You need to:
Originally Posted by qtiger
Do compression test, post the results, and if the numbers are funky you'll need to do a leakdown as well.
Old Oct 12, 2006 | 06:13 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Sorry, man but those are all of the symptoms of head lift. Get ARP studs for like 115$ or so, a mls gasket from autozone for 40$ and some copper gasket spray and you'll never have that problem again.
Old Oct 13, 2006 | 10:25 AM
t3t4delsol's Avatar
t3t4delsol
the mls head gasket how many layers is that?
Old Oct 13, 2006 | 12:36 PM
Omniscient's Avatar
Omniscient
3
Old Oct 14, 2006 | 12:09 AM
t3t4delsol's Avatar
t3t4delsol
thank you
