No Cluster Lights :(
Old Oct 3, 2006 | 01:00 PM
bleach's Avatar
bleach
Default No Cluster Lights :(
The Main Cluster light, (speedo, etc) is not working in my car, I've replaced the harness that goes to the cluster, and the cluster. Checked my fuses. What am I missing ?
92 civic hb/ b16a EX MT cluster
Old Oct 3, 2006 | 01:23 PM
orbit77's Avatar
orbit77
did you have an aftermarket headunit? if you have the illumination wire hooked up it is possible that is causing the problem.
Old Oct 4, 2006 | 07:15 PM
goldjdm's Avatar
goldjdm
dimmer switch
Old Oct 5, 2006 | 09:24 PM
rjmancia's Avatar
rjmancia
**hOnDaFrEaK**
you should just get some jdm white reversed gauge faces with LED lighting it works awsome and lights up pretty damn bright!!! check out eddie 001.bmp
Old Oct 5, 2006 | 09:25 PM
rjmancia's Avatar
rjmancia
**hOnDaFrEaK**
Originally Posted by rjmancia
you should just get some jdm white reversed gauge faces with LED lighting it works awsome and lights up pretty damn bright!!! check out Attachment 64689
i would show you them in the night but i dont have any pics in the dark but i will get some for you tomorrow
Old Oct 6, 2006 | 08:08 AM
Ambiguous's Avatar
Ambiguous
where do you get the bulbs for clusters?
Old Oct 6, 2006 | 09:05 PM
rjmancia's Avatar
rjmancia
**hOnDaFrEaK**
autozone or some auto shop store... just take the bulb in and they will tell you
Old Oct 10, 2006 | 03:12 PM
bleach's Avatar
bleach
I don't have aftermarket overlays. My clock, and (brake, signal,) lights show up on the cluster, just the actual tach/speedo/gas/temp lights don't show
Old Oct 16, 2006 | 11:08 AM
bleach's Avatar
bleach
