fuel issues ?
Old Sep 30, 2006 | 12:20 PM
twin3037's Avatar
twin3037
Default fuel issues ?
so i ahve a 93 civic hatch which should have a 12 gallon tank. Yet when i push the car till it starts to spurter and die it only fills up 8-9 gallons which is 3-4 short of the full tank. Then my engine is throwing code 43 which is fuel delivry system im assuming this would be a fuel pump issue but anyone want to confirm so i don't buy the wrong aprt
Old Sep 30, 2006 | 01:15 PM
t3t4delsol's Avatar
t3t4delsol
fuel pump or fuel filter and are you sure its a 12 gallon tank my sol only has a 10 gallon
Old Sep 30, 2006 | 10:47 PM
Kai's Avatar
Kai
Rotorphile.
I'm pretty sure the lower model EG hatchbacks came with a 9 gallon tank, the CX at least.
Don't run the car out of gas, it's bad for the fuel pump.
Old Oct 1, 2006 | 09:30 PM
twin3037's Avatar
twin3037
yes but as i said the si has a 12 gallon and i have an si
Old Oct 1, 2006 | 10:21 PM
Kai's Avatar
Kai
Rotorphile.
You did not mention in your first post that you have an Si, so I included that bit.
If you have a 12 gallon tank, it shouldn't start to choke out of fuel until you are 10.5-11 gallons down.
Old Oct 3, 2006 | 04:21 AM
twin3037's Avatar
twin3037
where is the fuel filter located and how do i replace it?
Old Oct 3, 2006 | 07:03 AM
t3t4delsol's Avatar
t3t4delsol
firewall close to the battery
Old Oct 3, 2006 | 07:09 AM
twin3037's Avatar
twin3037
ha it's making an awful humming noise so i hope tahts it it's cheaper then fuel pump
