hey motor problems
Old Sep 29, 2006 | 06:40 PM
jrw1818's Avatar
jrw1818
Default hey motor problems
what's the problem if a motor is running lean?
an what is the problem if the motor runs rich?? if there a site that explains all the problems of a motor an how it happens??
Old Sep 29, 2006 | 08:53 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
MAP or MAF sensor
Old Sep 30, 2006 | 01:58 AM
Snoopy's Avatar
Snoopy
been there done that
rich = too much fuel
lean = not enough fuel
Old Sep 30, 2006 | 09:59 AM
project_hatch's Avatar
project_hatch
Power by Uncle Ben's Rice
If your CEL is on, your car is running safety mode and will run rich. Basically, your ecu will dump fuel into the car to keep it running but having done this, will not allow the engine to reach peak performance...
Old Sep 30, 2006 | 11:27 AM
descivic's Avatar
descivic
also if your o2 sensor is bad your call will run rich so check that also
Old Sep 30, 2006 | 04:44 PM
jrw1818's Avatar
jrw1818
i guess i should of been more specific... i know when a car in running lean means not enough gar an rich means too much... if the motor is runnin lean it could be the fuel pump or fuel filter or the sensor.. which sensor is it besides the o2??
an if the motor is running rich why?? besides o2??
Old Oct 2, 2006 | 03:38 PM
descivic's Avatar
descivic
ah shit man I dunno, it could be your Fuel pressure regulator, Is your car throwing a CEL?
Old Oct 2, 2006 | 08:39 PM
jrw1818's Avatar
jrw1818
check engine light is on...
Old Oct 3, 2006 | 07:17 AM
t3t4delsol's Avatar
t3t4delsol
go to autozone and get them to read the code
