DOHC ZC questions
Old Sep 29, 2006 | 05:19 PM
PreludeSiprojec's Avatar
PreludeSiprojec
Default DOHC ZC questions
i got a dohc ZC its obd0, i want to put it in my 92 civic.
i have the d-series hydrolic tranny which should work. and i have both wiring harnesses. i heard that i could use my old d15 wiring harness on the zc and all i will need is the dohc obd1 distributer and the injectors.
is this correct? i also have the crx Si ecu but its obd0 so it wond fit, can i just use the stock d15 ecu?
i just heard that you could, but i wasnt sure if the ecu would work or not..
oh yeah, one more question. will the motor mounts from the zc work in my car?
thanks
