ign problem
d16z6 turbo running uberdata.
O.K. where do i start. my car gets no spark we switched out distributors, and changed the ecu and the fuel pump doesn't turn on. when my car first died it poped the ign fuse under the hood. we replaced that and still nothing. I am out of ideas does anybody have any others.
why would you change the ecu if you are running uberdata on the one, put the chipped ecu back in, i dont know you set up but you are probly running 440cc or 550cc injectors, are you using a resistor box for low impedence injectors or dsms? If you are I would mark that as your problem
