SRS problem on a 2000 Acura EL
Old Sep 12, 2006 | 11:48 PM
groovyman's Avatar
groovyman
Default SRS problem on a 2000 Acura EL
The SRS light came on over the weekend. I took it today to an Acura service department and they hooked it up to the computer. Result was a Code 01-2. Increased resisitance in driver side airbag inflator. Code cleared when it was reset. But as soon as I got into the car it came back on again. I was told that they would now have to check through flow chart (DTC 1-1 & DTC 1-2) and that it could be the cable reel or the air bag itself.
The whole thing is a 21 step procedure and they didn't know how long it will take.
Any advice would be greatly appreciate it.
Thanks in advance
Old Sep 13, 2006 | 09:05 AM
bnuk's Avatar
bnuk
I would say the cable reel, and its also going to be the cheapest thing to try..
Old Sep 13, 2006 | 07:48 PM
stereo's Avatar
stereo
check the plug first if snug check the horn & cruise control if both works fine. then might be the airbag but if they dont work replace the clockspring (cable real) but try the manual reset.
Old Sep 14, 2006 | 08:19 AM
bnuk's Avatar
bnuk
when you reset it, does it come back on randomly or when you are turing the wheel?
