Fuel Pump going bad?
Old Sep 8, 2006 | 04:11 PM
jessid163's Avatar
jessid163
First Time For Everything
Default Fuel Pump going bad?
Ok heres the DL im pretty pist but anywho....car lately has been having a hard time starting its NOT the charging systems I checked that at my work so thats a.ok...the second thing that popped into my head was the fuel pump...Im going to check that this weekend with the fuel pressure gage. If its NOT that anyone got any suggestions what I should check out next?!
Old Sep 8, 2006 | 08:33 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Fuel filter
Old Sep 11, 2006 | 11:19 AM
mberndt's Avatar
mberndt
What kind of car?
EG civic's are NOTORIOUS for the main relays going bad. <-- do you hear the fuel pump priming when the key is turned to the on position? If not, it's your main relay, guaranteed. have 2 EG's both had same problem...
Can you explain better the "hard starting"
Is it just cranking over and over then it starts?
Some more info and we'll figure it out
Old Sep 11, 2006 | 12:05 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
Helms suggest to check:
PGM-FI relay (main relay)
Fuel Pump
Fuel Filter
..in that order. Good luck. Im having the same symptoms on my setup as well.
