It all started so innocently
Old Aug 15, 2006 | 06:48 PM
Hondaman's Avatar
Hondaman
Black Pearl
Default It all started so innocently
So I went to change the oil in my civic tonight and found out the oil pan has a hole rusted in it. wned: CRAP!! I guess you can expect that after being in 10 Wisconsin winters. So, off to Majestic Honda to buy a new one...
Oil pan - $62.28
Oil pan gasket - $22.32
So, me in my infinite wisdom decide that now would be a good time to figure out my weird idle problem since I can't drive it until my new oil pan shows up. For about the last year, the car would idle very erratically when it is cold or warm. For example, when the car was warm, it would idle around 1200-1500 RPM. Let me tell you, it does not like going into reverse at that speed. If I shut the car off, and restart it, the idle goes back to normal. So I pulled off the intake manifold to fully clean the intake, throttle body, and IAC. I pulled the IAC apart and found out the valve shaft inside is very sticky and I can't get it cleaned/freed. Almost like the little bearing is failing inside the IAC valve not allowing the shaft to spin freely. Once again, off to Majestic Honda to buy more parts...
Intake manifold gasket - $4.79
Throttle body gasket - $0.41
Map sensor o-ring(old one looks brittle and cracked) - $1.56
PCV Valve(might as well replace it while I'm in there since it's easy to do with the manifold removed) - $12.16
Oil pressure switch(might as well replace it while I'm in there since it's easy to do with the manifold removed) - $5.81
IAC Valve - $138.94
After going through my service records I notice that the car is due for a transmission fluid change. I pulled the dip stick on the transmission and the rubber surround that holds the dipstick in has shrunk to the point that it doesn't seal. That's no good...
Dipstick ATF - $11.96
Moral of the story - Don't change your oil, it's too expensive. :cry:
Old Aug 16, 2006 | 07:12 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
I have a buddy of mine who did that with his celica for about 9 months past its due date.
I got to be the lucky one driving it when it finally threw a rod
Old Aug 16, 2006 | 08:28 PM
FrozenAcid's Avatar
FrozenAcid
That sucks dude. I hate when i go to fix something and i decide its a good idea to fix stuff that is in or around the area i'm working. Cars cost too much money. I wish i had a elephant to ride to work.
Old Aug 16, 2006 | 08:56 PM
Kris1212's Avatar
Kris1212
elephants would be pretty awesome to ride..i should invent a teleporter for my senior project this year
Old Aug 17, 2006 | 08:03 AM
quik's Avatar
quik
1337 h4x0r
yeah well my elephant's trunk is actually a ram-air.
Old Feb 3, 2007 | 10:37 AM
OptimusPrimeSr's Avatar
OptimusPrimeSr
Hondaman - did you ever end up fixing the eratic idle?
Old Feb 3, 2007 | 11:04 AM
19.3secS2K's Avatar
19.3secS2K
:doh:.
