Fuel injector help
So took my car down to the shop today to get my fuel system checked out and it turns out that my fuel injectors are leaking fuel into cylinders 3 and 4 and that's whats causing the motor to start up funny and it also explains the white smoke when the motor is cold. So I need to get 4 new injectors but I'm wondering what the best aftermarket injectors are to get and if I should get bigger injectors or not. I'm pretty much in the dark when it comes to fuel systems and I don't know much about it so any suggestions on what to get and a good website to get them from would be much appreciated. If it helps my mods are: intake, header, exhaust, obd-I conversion, chipped ECU and a mini-me head swap, clutch and lightweight flywheel. Thanks guys. Like I said, fuel systems is not my area.
Your stock injectors are fine for that setup. Just get a set of used stock Honda injectors off ebay. They are pretty cheap. The only time you need more fuel is with forced induction or a monster N/A setup.
jaje
News & Rumors Archives
Aug 11, 2006 09:29 AM
Daniel
Oct 6, 2003 11:46 AM
Daniel
Sep 25, 2003 02:43 PM
Daniel
Sep 23, 2003 12:24 PM
