Kill switch
Old Aug 2, 2006 | 04:36 PM
95LSv's Avatar
95LSv
Banded
Default Kill switch
I put a kill switch on my ek yesterday. I put it on the yellow wire with the green stripe. It works and everything, but I don't know what the wire is. I was shooting for the fuel pump, but it doesn't feel like the fuel pump... So can anyone tell me what that wire is, and if its ok to have a switch on it. Thanx
Old Aug 2, 2006 | 04:42 PM
ReVenGe's Avatar
ReVenGe
lol.... "i dont know what the wire is"
for some reason that sounded realy funny....
can you take a picture? im not too good with colors, but i am with pin outs.
and thats cool that it works
Old Aug 2, 2006 | 05:25 PM
95LSv's Avatar
95LSv
Banded
lol yea i was aiming for the fuel pump, but sounds like i got the dizzy or ignition... Well, its on the A connector, its the only yellow wire w/ a green stripe. Kills the car instantly
Old Aug 2, 2006 | 10:17 PM
95LSv's Avatar
95LSv
Banded
Anyone??
Old Aug 2, 2006 | 10:25 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It's the ICM signal.
I can't believe you would tap into a wire that you had no idea what it did. Pure brilliance there.
Old Aug 2, 2006 | 10:28 PM
95LSv's Avatar
95LSv
Banded
Lol, you're right, that was a dumbass move... But I thought it was the fuel pump, and I could always reconnect it. So what does the ICM signal wire do?
Thanx Schmoo
Old Aug 2, 2006 | 10:36 PM
Provocateur
On permanent hiatus
Thanx Schmoo
It regulates spark. Since it is being shut off, the car will naturally die instantly. The ICM is probably a better idea because the car will still run for a few seconds with the fuel pump cut off, but the ICM makes it die right away.
Old Aug 2, 2006 | 10:48 PM
Seruy's Avatar
Seruy
If the car is originally turned off, then you're not even going to be able to start it are you? With the fuel pump it will start and run for 2 secs and then die. I'd say install both switches, can never be too safe. Never thought about this ICM kill switch, but it's too late anyway.
Old Aug 2, 2006 | 11:10 PM
95LSv's Avatar
95LSv
Banded
Yea with the fuel pump it will run a while, and you can start it up... We tested my friends g2, the cut the fuel and it ran for 4 secs floored... Im glad to know that I got lucky and the ICM works out better, but i'll probably put one onto the fuel pump too
