suspension issues.
Old Jul 27, 2006 | 02:49 PM
eg_bert's Avatar
eg_bert
hoooorraayy Beer
Default suspension issues.
Last winter i missed calculated a turn in the snow and hit a curb probably 5-10mph. I got an alignment and noticed it pulled to the right and did some looking around and noticed the my lca was bent, the wheel was pushed back towards the passenger side door. so i recently replaced the front right lca and now the wheel is centered.
The problem now is that my front passenger side sits about 3/4 inch higher than the left side. I also noticed the the camber is a bit off on that side. Im lowered on s tech springs so i should be having negative camber all around. That side looks close to 0. ive also replaced the suspension fork but that didnt change anything. Any ideas?
Old Jul 28, 2006 | 04:07 AM
m735is's Avatar
m735is
Is it the correct fork, same height as the original one? Did you torque the LCA with the suspension loaded? Maybe the bushings are keeping it up alittle, which would wear them out fast.
Old Jul 31, 2006 | 06:27 PM
eg_bert's Avatar
eg_bert
hoooorraayy Beer
hmm no i didnt load the suspension. that sounds like it might be the issue, Ill give that a try and yes the fork is the same. Thanx
