h22 vs. k20a
Originally Posted by RedlineBoyzCRX
To be honest if you are going to go thru all the trouble of going K, y not just go K20a2? Go with VTEC, I mean wtf why not?
and there is a big difference in price between the k20a3 and the k20a2....i can get a a3 for about 2300 and the a2 is like 5500, there is only an 800 diffence between the a3 an a2 thats why i was thinkin of gettin a k20 over a h22
i've added all the mess up, the h22 is about 3100 and the k20 is about 4000. thats including mounts, axles, the harness adapters, and the engine. but before all that i am getting a full coilover setup and brake upgrade (i didnt add those 2 in). the mounts/axles/harness i am ordering from hasport, and engine from osakajdmmotors.com and its a complete motor
looking good keep us up to date
no offense, but this is a retarded thread. dollar per HP, or dollar per lb-ft or dollar per grin-factor, the H22 toasts the k20 in every facet.... better torque production, similar power output and about three grand less invested. Don't waste your money on popularity, son.
isnt the only differnce between the k20a3 and the k20a1 the camshafts? and maybe the vavle cover color. cause if i'm not mistaken they're the same engine, different heads
If you're trying to decide between the H22 (200HP/156ft-lbs) and K20A3 (160hp/132ft-lbs), the obvious choice (at least to me) is the H22. More power (+40hp/24ft-lbs) and less money. Besides for little more on the H22 ($300 at HMO comes to mind) you can get a factory LSD with the H22. K also has a five speed, but no factory LSD option, so there's money saved.
Now if you can afford a K20A2 (200hp/142ft-lbs) w/ a 6spd, that could be fun, but it's a lot more than a H22 is. Or the really awesome K20A (220hp/155ft-lbs), comes with a 6spd w/ a LSD. Of course it's around $5500.
A grand more than a H22? I wish!!
The K20A2 is about $1800-2000 more for the engine. They both need custom mounts, axles, and wiring.
My guess would be that for a grand or so more, you can do the k20a2 swap.
