a/c woes
Old Jul 16, 2006 | 05:55 PM
dawgking's Avatar
dawgking
Default a/c woes
allright honda freaks. I have a 93 civic witha 1.5. i have a/c problems, sometimes the compressor kicks in and sometimes it don't. i have basically redone the whole system and replaced the drier and compressor. i also replaced the binary switch and the system worked fine. now the compressor and the condensor fan won't come on, but when i check the binary switch with the test light the fan and the clutch kick in. i thought it might have been a bad ground but when i redid the ground, it still wouldn't work. anyone have any ideas before i have to take it to the garage??????
Old Jul 16, 2006 | 05:59 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Take the AC & PS out and run a CTR N1 Crank Pulley. I live in FL and I took mine out.
Old Jul 21, 2006 | 06:30 PM
dawgking's Avatar
dawgking
hey guys,
i still have on again off again clutch kick in. i have changed the compressor and the drier and the a/c binary switch. i filled it with freon, no bubbles in sight glass, sometimes it cools like a mad dog and sometimes it don't. got in today and no a/c. compressor won't kick in but can ground pressure switch wires and kick the compressor in. Helppppppppp!!!!!!!!
Old Jul 23, 2006 | 07:04 AM
wcooksey's Avatar
wcooksey
Are High Side pressures good? If your expansion valve is freaking out, couldn't it be the culprit? If the valve won't let liquid through, then pressures go up and switch keeps system from coming on?
Just a thought.
William
Old Jul 23, 2006 | 08:53 PM
stereo's Avatar
stereo
maybe the climate control switch ?
Old Jul 24, 2006 | 05:45 PM
dawgking's Avatar
dawgking
where might the little culprit, the expansion valve be located? is it under the dash with the evap core? don't see it in the engine compartment.
Old Jul 25, 2006 | 02:31 PM
stereo's Avatar
stereo
if it's the expansion valve it won't keep it from turning on junst no cold air! it's in the evaperator unit. and be careful of the test light as they are not the safest things to use on modern cars.
Old Jul 26, 2006 | 08:18 PM
nemesis2's Avatar
nemesis2
Check to see if the pressure in the line is high/low.
