Broken LCA bolt, bolt stuck in frame
Old Jun 16, 2006 | 10:24 AM
eonsx311's Avatar
eonsx311
today is not my birthday.
Originally Posted by Kestrel
You could try a bolt extractor first too
that wont work in this case, all you can do is drill it out, grind/cut the welded bolt end off and replace with new hardware (hardned steel only)
Old Jun 16, 2006 | 10:28 AM
aenima_20's Avatar
aenima_20
I dont think I can fit a grinder in that little recess its not very wide
Old Jun 16, 2006 | 10:53 AM
eonsx311's Avatar
eonsx311
well where it's verry corroded, i would try drilling first and see how much of the weld still remains holding that to the subframe. i had just a sliver of steel that was holding mine on so i was able to just rip if off with pliers. if that dosn't work than i don't know mang. good luck.
edit: after you drill it and are able to get the lca out, just bring it to a machine shop and they can drill that welded bolt on a drill press with a larger bit or if you have a drill press, DIY
Old Jun 16, 2006 | 11:54 AM
aenima_20's Avatar
aenima_20
the LCA is already out
the nut(which has a piece of the bolt stuck in it) is welded to the subframe
Old Jun 16, 2006 | 12:29 PM
eonsx311's Avatar
eonsx311
A machine shop can take care of it if you cant, check the phone book.
Old Jun 16, 2006 | 12:43 PM
wilsel's Avatar
wilsel
I just put socket on mine, and put some ass into it. The welds broke, and the nut was off (with what was left of the bolt)
Old Jun 16, 2006 | 01:47 PM
aenima_20's Avatar
aenima_20
thanks a lot buddy!! :cheers:
this method took me a big 45 seconds
if anyone has this problem, the nut is only held on to the sub frame by like 3 small spot welds
Old Jun 16, 2006 | 02:00 PM
m735is's Avatar
m735is
I broke off my front inner control arm bolt in the nut, now THAT was fun to fix!
Old Jun 16, 2006 | 04:03 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
glad to hear that you got it off. Let us know what you end up using to secure the lca back on with.
Old Jun 19, 2006 | 07:03 AM
aenima_20's Avatar
aenima_20
just nuts and bolts
