h22??
im gonna put a h22 in my sol, anyone have any usefull information regarding the swap? Here are a few things i would like answered, is there any i can get off another car so i dont have to buy a set for $400?
Wiring harness, can the orginal one be used without buying an adapter, and is there any wiring besides the ones to the main harness that im gonna need to worry about?
The shifter cables, any suggestion to changing from rod type to cables?
Anyone ever done a swap without a lift? if so any ideas how to lift the car up to drop the engine out.
handling, does anyone know how the car will actually handle, i dont want ideas, does anyone actually know?
let me know what you think of an h22 in a sol, good?...bad?.....gimme a score of 1 out of 10
the only part i could understand was the taking out the engine part...
you dont need a lift... just an engine jack/cherrypicker
and handling is fine...the weight difference is actually quite minimal
Originally Posted by b20hatchy
The next time someone has a b series out of there car and a h they need to weigh them.
h: I think... it was below 100
h:
I knew that question looked a little familiar.
https://www.honda-acura.net/forums/s...ht=h22+del+sol
If you want all motor and/or loads of turbo power, H22 is a great idea. :thumbup: If you want an easier route, go B-series. It's going to take more work than a B-series (mainly in the mounting and shifting department, wiring is the same as a B18C), although not a lot more. Do it right, get good mounts and quality axles. Read this: http://www.honda-tech.com/zerothread/650329
That will explain in detail how to do everything.
