motor swap
Old Jun 7, 2006 | 08:44 PM
Nick20588's Avatar
Nick20588
Default motor swap
I was wondering what all i have to do to put a b16a dohc motor into a 92 civic 4 door like if i have to get new mounts axles ect
Old Jun 7, 2006 | 08:52 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
New motor mounts, shift linkage, axles.
Old Jun 7, 2006 | 09:02 PM
eonsx311's Avatar
eonsx311
today is not my birthday.
The best swaps for the B16A2 with hydraulic transmission are:
92-Up Civic
93-96 Del Sol
94-Up Integra
The B16A2 is a direct swap into these cars unless it is OBDII; in this case you would need an adapter. OBDII cars are usually 96-Up.
Modifications for swapping the B16, B18, H22, or ZC:
88-91 Civic/CRX will require a motor mount kit. This kit requires no welding and since it is adapted to your current mounts it is easy to put back to stock if you wanted to.
You need to get axles from a 90-93 Integra (if your 88-91 CIVIC/CRX is the DX model you will need a 90-91 Si wiring harness, or modify your harness to run four injectors. Shift linkage is also required.)
ZC will bolt straight into the 88-91 Civic/CRX (The Si model needs no additional parts on any other non Si models you need a wire harness, and Si axles)
The 90-93 Integra is a more straight forward swap. If your vehicle is a 90-91 model the B16-5000 will bolt onto your existing motor mounts with no modification. The ECU and distributor should also plug straight into your existing wiring harness.
92-93 Integra B16A2 motor will work with your harness because it has the grey plugs, then just swap the hydraulic transmission for a cable transmission from a B16A.
94-99 Integra you can swap any B series motor with a few wires added for the VTEC solenoid and knock sensor.
92-Up Civic/Del Sol, 94-Up Integra needs the B16A2, B18C5, or B18C motor. These motors bolt straight in and will work on models that are not OBDII, unless you change the entire wiring harness or use an adapter. You also need to get axles from a 94-Up Integra GSR or 99-Up Civic Si.
H22 into a 92-Up Civic, Del Sol or 94-Up Integra requires a motor mount kit and axles to work.
The B18c and B18C5 are 1.8L DOHC VTEC engines. They fit the same mounting as the B16A2 engine. It will fit all the applications above that are 92-Up and use a hydraulic transmission. To fit it into an older model you will need motor mounts and an adapter for the cable to hydraulic transmission.
90-97 Accord, 92-96 Prelude need the H22 engine. B16 or B18 engines will not fit or work well if swapped into these cars. These cars are too heavy for the smaller engine. The H22 will bolt straight into either of these cars. In the 92-96 Prelude it is a direct swap into with no other parts required unless you are converting to a manual transmission. For the H22 into the Accord it will also bolt straight in. 94-97 will also plug straight in with only the VTEC solenoid and knock sensor to be hooked up if your car was not VTEC in the first place, 90-93 model requires rewiring.
Some of the parts for these motors are the same as some as some other US models. The B16A and B16A2 can use parts from the 93-Up Del Sol VTEC DOHC such as head gasket. The intake and exhaust manifolds use the same bolt pattern on most 1.6L and 1.8L DOHC motors except the ZC.
edit: i searched for you K)
