Online Resources Thread - Updated 7/04/2006
Old Jun 4, 2006 | 08:05 AM
qtiger's Avatar
qtiger
Default Online Resources Thread - Updated 7/04/2006
First and foremost, Civics and Integras have ONE HEAD|ER|. Header(s) refers to multiple whereas these vehicles only use one headER due to the design of the exhaust manifold. Please, keep this in mind.
Research Information
www.howstuffworks.com
Manuals & Parts Catalogs
Various Helms Manuals: http://www.redpepperracing.com/technical/main.php
Parts Catalogs & Manuals: http://icelord.net/honda/repair/
Electrical
5th gen Civic underhood fuse diagram: http://spoon.org/civic/pics/93-Civic-Fuse-Block-2.jpg
5th gen Civic interior fuse diagram: http://spoon.org/civic/pics/Interior-Fuse-Panel.jpg
5th gen Civic fuse legend: http://spoon.org/civic/pics/93-Civic-Fuse-Block-1.jpg
Check your Check Engine Light (CEL): https://www.honda-acura.net/forums/s...d.php?t=185065
Check Engine Light (CEL), what do I do?: http://www.c-speedracing.com/faq/03.php
Check your Check Engine Light (CEL): http://www.c-speedracing.com/faq/06.php
Define your Check Engine Light (CEL): http://www.c-speedracing.com/faq/05.php
Resetting DelSol's ECU: http://www.austrosol.com/tips/reset_ecu_eng.htm
Engine & Tuning & Cooling
Skunk2 B18C1 intake manifold DIY (it's not just a bolt-on mod, the TB bracket will hit your hood if you don't follow these instructions): http://www.ff-squad.com/tech/howto/sk2manifold/
Skunk2 B18C1 intake manifold & Hondata intake gasket DIY: http://repo.jackmoves.com/v/erik/alb...m129/album215/
96-2k Greddy oil catch can install (NA/FI): http://repo.jackmoves.com/v/erik/alb...m129/album130/
96-2k Integra radiator swap (doesnt retain AC): http://repo.jackmoves.com/v/erik/alb...bun03/albun46/
Bseries STR Cam Seal Install: http://repo.jackmoves.com/v/erik/alb...m157/album159/
Bseries Skunk2 Cam Gear Install: http://repo.jackmoves.com/v/erik/alb...m157/album158/
DelSol home made air duct: http://www.impactsites2000.com/autozone/delsolmod_2.htm
Clutch/Flywheel replacement: https://www.honda-acura.net/forums/s....php?p=1715569
---:Forced Induction (FI) Related:---
Turbocharging basics - LOTS of information: http://www.beesandgoats.com/boostfaq/g2icturbo.html
DIY Boost Controllers: http://www.c-speedracing.com/howto/mbc/mbc.php
Another DIY Boost Controller: http://www.geocities.com/chmwatson/FAQs/mbc.html
Basic Maintenance
Axle Replacement: https://www.honda-acura.net/forums/s...d.php?t=173647
Clutch/Flywheel replacement:https://www.honda-acura.net/forums/s....php?p=1715569
Fuel pump replacement:https://www.honda-acura.net/forums/s....php?p=2337636
How to Change DelSol Spark Plugs: http://www.impactsites2000.com/autozone/delsolmod_1.htm
Civic/Teg - Changing front & rear disc brake pads and rotors: http://www.g2ic.com/tegtips/brakesus/5.html
Drivetrain
15 minute axle replacement: https://www.honda-acura.net/forums/sh...d.php?t=173647
Clutch/Flywheel upgrade DIY: https://www.honda-acura.net/forums/sh....php?p=1715569
Bseries tranny specs: http://www.bseries.net/html/specs/btrannyspecs.php
Hybrid
92-95 Civic B18C1 swap: http://www.c-speedracing.com/howto/b18cswap/swap.php
96-2k B18C swap: http://repo.jackmoves.com/v/erik/alb...bun03/albun45/
Kseries into 92-95 Civic, 94-97 Sol, 94-01 Teg: http://www.k20a.org/EGK1.pdf
Kseries into EK: http://www.k20a.org/EKK1.pdf
Brakes & Suspension
Omni Power Camber Kit:https://www.honda-acura.net/forums/s...79#post2209279
Rear Camber Adjustment (Cheaper than a Kit): http://home.earthlink.net/~civicex95/rearcamber.html
96-2k rear integra disc brake swap: http://repo.jackmoves.com/v/erik/album53/album55/
96-2k Power steering and swaybar conversion: http://repo.jackmoves.com/v/erik/album106/album119/
ITR master cylinder swap: https://www.honda-acura.net/forums/s...d.php?t=134103
Exterior
DIY for fitting H4 HID's in an H4h housing: http://www.turntableteknicianz.com/carpics/TL%20HID.htm (if you can get a D2R/S bulb)
Difference between H4 and H4h:
http://oregonstate.edu/~blackry/pic...s/h4andh4h3.jpg
http://oregonstate.edu/~blackry/pic...s/h4andh4h2.jpg
http://oregonstate.edu/~blackry/pic...rs/h4andh4h.jpg
(H4h is the smaller/shorter bulb)
'96-'98 Civic all OEM power window converstion: http://repo.jackmoves.com/v/erik/album106/album206/
92-95 power window/mirror/lock conversion: http://repo.jackmoves.com/v/erik/albun31/albun42/
99-00 Si Lip Install on EG: http://www.jdmvtec.com/silipinstall.html
92-95 to 96-2k mirror conversion: http://repo.jackmoves.com/v/erik/albun31/album104/
99-2k Grille removal (realy simple): http://repo.jackmoves.com/v/erik/alb...m129/album146/
Painting your headlight housing:https://www.honda-acura.net/forums/s...ad.php?t=56277
Interior
Integra GSR Cluster in EG: http://www.geocities.com/cinq112/gsrclusterswap.html
GSR cluster into civic wiring diagram: https://www.honda-acura.net/forums/a...id=51278&stc=1
6th Gen gauge cluster swap - entire cluster swapped: http://repo.jackmoves.com/v/erik/alb...m138/album161/
96-2000 detachable steering wheel install with SRS disable: http://repo.jackmoves.com/v/erik/alb...un41/album244/
96-98 Civic Dash swap to 99-00: http://repo.jackmoves.com/v/erik/album106/album228/
Security
Fuel Pump Cutoff Switch: http://www.teamdelsolwa.com/howto/fuelcutoff.htm
96-00 Hood Lock Installation: http://repo.jackmoves.com/v/erik/alb...m268/album269/
Misc & Large Listings
Numerous Del Sol How-Tos: http://www.teamdelsolwa.com/howto.html
Many excellent engine/suspension/fuel/etc. DIYs: http://www.c-speedracing.com/howto.php
DelSol Technical Specifications: http://members.lycos.nl/hendrik/delsol/soltech.htm
Many, many important resources: http://www.hondaswap.com/forums/index.php?showforum=33
96-2k complete front subframe swap/repair: http://repo.jackmoves.com/v/erik/album106/album139/
Bunch of great DIYs: http://repo.jackmoves.com/
HAZONE various DIYs: http://www.hazone.com/hhowto.htm
HONDA's own DIY install instructions: http://www.hondaautomotiveparts.com/instal/instal.htm
Spectacular set of articles here (includes N/A B20 build-up, engine building tips, and more): http://www.theoldone.com/articles/
KILLER ECU Info: http://ecu.ff-squad.com/info.htm
More Tech Info than you can shake a stick at: http://technet.ff-squad.com/
D and B series engine specifications: http://hybrid2.honda-perf.org/tech/engine.html & http://www.bseries.net/html/specs/benginespecs.php (Bseries only)
Wheel offset info:https://www.honda-acura.net/forums/s...50&postcount=2
Old Jun 4, 2006 | 08:09 AM
qtiger's Avatar
qtiger
Cleaned up, a few things added, a few things removed (all hybridgarage stuff).
You may post in this thread if you have a link you think should be aded.
Old Jun 9, 2006 | 07:16 AM
eonsx311's Avatar
eonsx311
today is not my birthday.
http://www.scottgrundfor.com/ideas/paint3.html
http://www.scottgrundfor.com/ideas/paint2.html
some good painting info on spray guns, technique etc...
Old Jul 21, 2006 | 08:45 AM
thebrowngirl's Avatar
thebrowngirl
just found this one -- it has owners manuals...
https://techinfo.honda.com/rjanisis/logon.asp
Old Dec 19, 2006 | 08:04 PM
enca's Avatar
enca
found some good resources:
http://www.aboutautomobile.com/TSBs.aspx
http://www.aboutautomobile.com/Recalls.aspx
Old Apr 15, 2007 | 01:58 PM
fathergoat's Avatar
fathergoat
:3
the parts catalog and manuals link no longer works, it seems to have been moved http://hondatech.info/downloads/Auto/Manuals/
Old Jun 4, 2007 | 07:41 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
NGK Spark Plugs explained - as posted by HatchVX:
https://www.honda-acura.net/forums/s...d.php?t=271268
Old Jun 4, 2007 | 08:18 PM
Civic2Scooby's Avatar
Civic2Scooby
so we add that, but not the useful threads for noobs......I agree that thread should be stickied, but...there are alot of others that should be too
Old Jan 8, 2008 | 04:59 PM
gettheledout's Avatar
gettheledout
DelSol home made air duct: http://www.impactsites2000.com/autozone/delsolmod_2.htm is no longer good
Old Nov 6, 2010 | 08:12 AM
TorqueSolution's Avatar
TorqueSolution
Hi,
nice information..thanks a lot for sharing the information....
