Ls Swap Questions
OK doing an LS swap what do i need I have a 98 honda civic DX HB i kno i need mounts Harness axles tranny ECU. Was also inquiring about the Radiator my radiator is from A 93 Bubble would that support the LS or would i have to change it. Also the wiring what would i have to mod need a basic DIY or anything that will help me with this swap
search on this site.
You'll need the 99-00 si rear trans mount, other mounts should be fine.
wiring wise I think you just need to convert to 2 wire IACV and that should be all. You are going to have to extend your o2 sensor wires to the rear of the engine.
The radiator will be fine
