searched: 97 integra brakes on my 98 hb
Old May 29, 2006 | 02:14 PM
buzzfast's Avatar
buzzfast
98 civic HB
Default searched: 97 integra brakes on my 98 hb
hey guys, im new here but not new to the forum aspect. Im trying to put calipers and the rotors off of a wrecked 97 integra onto my 98 hatch back. what my question is, can i just swap the hub out or is there a caliper re-mount kit that I can purchase. thanks
Old May 29, 2006 | 02:17 PM
CivicRacr's Avatar
CivicRacr
you;ll need the front knuckle/hub from the integra
Old May 29, 2006 | 02:20 PM
buzzfast's Avatar
buzzfast
98 civic HB
so the hub will bolt right up? and thats all i need?
Old May 29, 2006 | 03:17 PM
buzzfast's Avatar
buzzfast
98 civic HB
and were doing the rear disc conversion,
is there anything else besides the e-brake cables, proportioning valve, trailing arms, master cylinder and brake booster that we will need?
and will it all fit up?
Old May 30, 2006 | 04:15 AM
Chem Geek's Avatar
Chem Geek
H22A powered EH2!
Here's a few threads about disc brakes swaps....
http://honda-tech.com/zerothread?id=812062
http://honda-tech.com/zerothread?id=820484
http://honda-tech.com/zerothread?id=641639
http://honda-tech.com/zerothread?id=1513752
http://honda-tech.com/zerothread?id=1030365
Old May 30, 2006 | 06:28 AM
mistacee's Avatar
mistacee
Zc powered ED9
Didn't search ahrd enough...
Step by step write up...
http://www.diynetwork.com/diy/ab_bra...275324,00.html
& more search results
https://www.honda-acura.net/forums/s...archid=1117506
Old May 31, 2006 | 06:53 PM
buzzfast's Avatar
buzzfast
98 civic HB
thanks for the replies. i put on the hub, calipers rotors and lines for the front. today i just finished putting on the integra lower arms, and bolted his sway bar in place. i didnt have one, damn cx moel. and i even got his rear sway bar to fit up to my stock stuff. the holes were already there.
so here's the list.
Integra spindles, calipers, rotors, brake lines, lower control arms, front sway bar and rear sway bar.
I took the rear apart and im going to conver that this weekend.
Trailing arms, calipers, rotors, e-brake cables, booster and master cylinder.
on top of that Im swapping the B-18 in, full exhaust, alarm, wheels, and anything else I want from the teg all in the name of $500.
Old Jun 1, 2006 | 09:52 PM
nblanton's Avatar
nblanton
The proportioning valve is the same on all Civics. Rear disc or not. The only difference comes in if you have ABS or not. Check the P/N's on 99-00 Si and 96-00 CX's. They're the same.
Old Jun 4, 2006 | 08:23 PM
buzzfast's Avatar
buzzfast
98 civic HB
i dont have abs, the integra does
