Help Asap
Old May 23, 2006 | 01:19 PM
Nicaraguense13's Avatar
Nicaraguense13
Default Help Asap
well this is my problem my car started with me giving it throttle and it would turn on then the car would try to idle and shut off we tried it agen and it would do the same thing after the third time it wouldnt start i took it to a near by mechanic he said no signal from the ECM going to the Injectors and no spark from the spark plugs (had to push car 5 blocks up hills with oncoming TRAFFIC) and well this is day 2 of this problem any SUggestiong ANY answers to this PROBLEM no injector SIGNAL and no spark from Spark plug wires HELP ASAP !!!!! 98 honda civic DX Hatchback
Old May 25, 2006 | 12:49 PM
Pete's Avatar
Pete
Civilian
Distributor problem? I had the same problem once but it had nothing to do with electrical issues. I swapped out my IACV with a good one and it fixed the problem. Are you throwing a code at all?
Old May 25, 2006 | 02:27 PM
waaBAAH's Avatar
waaBAAH
if no spark....and no fuel....i would check all grounds. including a known good ecu
Old May 25, 2006 | 02:31 PM
Exempt's Avatar
Exempt
2 tone Rex
Or the ECU fuse... I believe its a 15 amp fuse in the under hood fusebox...
Old May 25, 2006 | 02:33 PM
jaje's Avatar
jaje
HC Racer H5
wrong forum...this is for 1992 and older Civic / CRX
Old May 25, 2006 | 04:32 PM
93CivicSiD16HB's Avatar
93CivicSiD16HB
mmmmm VTEC..
Okay this guy has a 1998, WHY are you telling people with 92+ civics to go to the pre 92 board!?!?!?!
Edit: i forgot why i was even posting, i had this SAME problem in the steps you did, mine ended up being a bad battery connection on the battery istelf. it was worn pretty bad for whatever reason and became loose. If that isnt it then i'd suggest digging into the engine. Also mechanics are good for doing actual work, but more likely than not, they usually go a little overboard with what is wrong. Get all your info and check all areas you can without paying anything first like the one i said, or checking your grounds. Only then, again, would I look into it being a serious problem.
Old May 25, 2006 | 08:31 PM
Exempt's Avatar
Exempt
2 tone Rex
Because he originally posted it in the Pre-92 Civic/CRX forum, which was the wrong one... It has since been moved...
Old May 26, 2006 | 10:11 AM
93CivicSiD16HB
mmmmm VTEC..
Ohh alright, my bad, i was still right in the 'deciding on a honda' post though!
Old May 26, 2006 | 12:26 PM
qtiger's Avatar
qtiger
Tried using fuel injector noids yet?
Problem is likely ECU or distributor.
Old May 26, 2006 | 04:10 PM
Exempt's Avatar
Exempt
2 tone Rex
Actually no, u were wrong there aswell...
