My car Revs up and down but doesnt die???
Old May 9, 2006 | 10:18 PM
characteristics's Avatar
characteristics
revs up and down warm cold hot anything before it would just do it everyonce in a while no it does it pretty much all the time unless it is idling for 5 or more minutes then it USUALLY idles good. and it hessitates everyonce in a while too.
Old May 9, 2006 | 11:08 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
I had my P28 ECU stolen, and had it replaced with a P28 from an automatic. The up and down reving came from having an automatic P28 in a 5-speed car. I tweaked the P28 and it stopped. Has your ECU been replaced?
Old May 10, 2006 | 02:18 AM
mini-me civic's Avatar
mini-me civic
yeahs sounds like ur IACV...
Old May 13, 2006 | 07:14 PM
tommyhcky13's Avatar
tommyhcky13
mine use to do that and it was a vaccum leak. lots or searching through hoses solved that one
Old May 16, 2006 | 07:35 AM
characteristics
i cleaned out the IACV it didnt really make a difference when the motor is cold and i start it it doesnt rev up and down for about a min now that is the only difference. any more ideas?
Old May 16, 2006 | 07:37 AM
HAve you checked for vacuum leaks?
Old May 16, 2006 | 07:49 AM
characteristics
I have checked. Is there a special way to check? What I did was un plug one side of the hose then plug the hose and the nipple. Is that what your supposed to do?
Old May 16, 2006 | 08:03 AM
That could work, but the hose itself might have a hole that you can't see... I sprayed engine cleaner the last time I had one and it was bubbling so I replaced it with a new one h: That might be over kill though but it worked for me
Old May 19, 2006 | 05:51 PM
VPUPPY's Avatar
VPUPPY
Check your fast idle thermo valve. Do a search on how to fix or replace it.
Old May 21, 2006 | 06:57 PM
96scgsrcoupe's Avatar
96scgsrcoupe
Yeah same problem with my gsr. The fit valve wasnt working properly.
