I can't get my injectors back in my fuel rail.
Old May 8, 2006 | 06:25 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Default I can't get my injectors back in my fuel rail.
Sounds cheesy, huh? I took it off and scrubbed it down to get some of the grime off and cleaned the holes with come carb cleaner then rinsed it out. I can't get my injectors back in, they came out pretty easily. Should I use some sort of lube on them?
Old May 8, 2006 | 06:31 PM
raiden571's Avatar
raiden571
turning u inside out
petroleum jelly, or the o-rings may not have been for fuel and they swelled
Old May 8, 2006 | 07:36 PM
qtiger's Avatar
qtiger
Just dip your finger in motor oil and smear it on there a bit, just like you'd do with the seal on an oil filter.
Old May 8, 2006 | 08:20 PM
Omniscient's Avatar
Omniscient
I did the oil thing because I have no petroleum jelly. Thanks a lot guys. Slid right in.
Old May 8, 2006 | 10:34 PM
Kai's Avatar
Kai
Rotorphile.
That's the way I always do it. The first time I replaced injector O-rings, I did it dry and tore two of the four.
Since then, I've used motor oil to lube and life has been easy.
