95 civic headlight problems
Old May 3, 2006 | 06:35 PM
civic8u0702's Avatar
civic8u0702
Team Elements
Default 95 civic headlight problems
My headlights are dim. I have to have my brights on so that I can drive comfortably. Its like there working fine because when low beam is on there low and when hi beams are on there high, but ther not even close too as bright as they used to be. I have even changed the bulbs several times. :thinking: has any one else had this problem?
Old May 3, 2006 | 06:37 PM
randomtask77's Avatar
randomtask77
Wanderer
Are they aimed properly?
How about the condition of the wiring?
Old May 3, 2006 | 06:38 PM
james_stewart's Avatar
james_stewart
I had that problem once. It ended up being my alternator dying on me. It took the alternator 3 months to finally die on me
Old May 3, 2006 | 08:12 PM
civic8u0702
Team Elements
I have done a motor swap and still its the same.the wires look fine
Old May 3, 2006 | 08:52 PM
gr3asemonkey's Avatar
gr3asemonkey
So wat if I have a CIVIC?
On my 95 hatch...i had the same problem. Even when I installed H.I.Ds it wasn't shooting far. Luckily I sold it and now i'm blastin my 8000k in my 99 Sedan.
Old May 4, 2006 | 06:10 PM
whiteblazer01's Avatar
whiteblazer01
Could it be the headlight housing? Maybe its dirty, or faded
Old May 4, 2006 | 06:12 PM
remy's Avatar
remy
is kind of ez to know if the alternator is dying on you...all u have to do is check the voltage!!!
Old May 17, 2006 | 09:05 PM
tommyhcky13's Avatar
tommyhcky13
do they get brighter when you hit the gas
Old May 18, 2006 | 09:18 AM
Running925's Avatar
Running925
Your Powder Coater
clean the hell outa the plugs & metal contacts, if that doesn't help.. begin diagnosing your charging system.
