hesitation
Old Apr 24, 2006 | 10:38 AM
archangel1927's Avatar
archangel1927
Boosted_JDM_SI
Default hesitation
so my 00 civic seems to hesitate sometimes when i give it gas, unless it is at WOT. i just got a new clutch and everything put in.. any suggestions??
Old Apr 24, 2006 | 10:55 AM
lowbrow's Avatar
lowbrow
12:00AM Atlanta time...
I'm gonna suggest default text, new plugs, filter, and wires. Then go from there.
Old Apr 24, 2006 | 10:57 AM
archangel1927
Boosted_JDM_SI
changed the font back.. now i still need to change the plugs, wires, and filter... any more suggestions???
Old Apr 25, 2006 | 01:31 AM
lowbrow's Avatar
lowbrow
Run a can of injector cleaning fluid through it too - never hurts.
Old May 10, 2006 | 07:26 AM
loonz123's Avatar
loonz123
not too hijack this thread, but i too have a similar problem.
i have a 94 ex sedan and getting more and more hesitation while on the throttle. this seems to be getting worse if i run wot no problems, but if i run light throttle i get hesitation. i have replaced all this, new plugs, new wires, new cap, new rotor, new fuel filter, ran cleaner w/full tank of gas. 99% stock w/ exception of cai this has been on the car for a long time with no problems. now even more there is no cel. only once when i took a hard turn.
Old May 10, 2006 | 11:31 AM
2000CivicSi's Avatar
2000CivicSi
Timing. Mine did the same thing. Hit the gas and it boggs down for a sec then finally goes. Re-timed and all better.
Also check for pinging. An Si requires premium so next time you fill up put in premium. I was running reg and mid and it was pinging. Little damage caused but fixed now. Do both.
Old May 10, 2006 | 02:13 PM
loonz123's Avatar
loonz123
thanks for the help, i will try this tomorrow.
