Tires don't spin
Old Apr 18, 2006 | 06:41 PM
cvchtchbck92's Avatar
cvchtchbck92
Anti-Ebayer
Default Tires don't spin
Well. I am done with the swap but for some odd reason I can't get the wheels to spin. I put it in gear and I accelerate but I don't move. Not on first or reverse. It gets the gears but the tires won't move. I don't have the vtec wired in yet because someone is doing a sub-harness for my vtec. But I doubt its the vtec that not letting me go. Anyways, I put the engine oil and gear oil in. Any ideas?
Old Apr 18, 2006 | 06:45 PM
ariza034's Avatar
ariza034
SuMaDiNaC
uhm ur axles arent in all the way check the axels!!!! lol some guy here had the same problem
Old Apr 18, 2006 | 07:13 PM
cvchtchbck92
Anti-Ebayer
My friend said the same thing. I took off the tires and torqued in the axles with a wood and a hammer until it no longer went in. On the driver side, if I torque it in I don't get enough thread to screw on the bolt. So I pull it just a bit so I can screw it on. Anyways, after that I check, and I turn the axle and the whole thing connected to the axle turns with it. So I'm pretty sure its on. Who knows, maybe I'm just incompetent when it comes to auto-mechanics. Any other ideas, or can anyone confirm?
Old Apr 18, 2006 | 07:14 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
Happened to me before on an axle replacement. Common thing to happen h:
Old Apr 18, 2006 | 07:21 PM
Kai's Avatar
Kai
Rotorphile.
Remember to connect the shift linkage? :chuckles:
Old Apr 18, 2006 | 09:22 PM
Kabooki's Avatar
Kabooki
happened to me, right after motor went in, axle wasnt in all the way, when i floored the gas, front raised enough for axle to come out a little and spin the teeth off the axle.
Old Apr 19, 2006 | 05:26 PM
ariza034's Avatar
ariza034
SuMaDiNaC
so did you figure out what the problem is or still....
Old Apr 19, 2006 | 08:31 PM
cvchtchbck92
Anti-Ebayer
Yeah. Sure enough. It was the axles. The passenger side wasn't all the way in. Thanks everyone.
Old Apr 20, 2006 | 07:45 AM
ariza034's Avatar
ariza034
SuMaDiNaC
i hate to say it I TOLD U
Old Apr 20, 2006 | 07:55 AM
b18c1_hatch's Avatar
b18c1_hatch
Had the same problem with my swap. I dident use the c clamp at the end of the axles. and the Drive side came out when i was merging.
